Originally Posted by
Sbthomas13
Joe-
Today was the second day of cutting and there were numerous improvements made from the first day of cutting. We made changes to the IPM and RPM of the router and we're able to make much cleaner, quicker, and quieter cuts.
Router Settings:
- 16,000 RPM
- 80+ IPM
- .18" passes
Bit Settings:
- Brand: Atrax (off of Use-Enco.com)
- 1/4" shank, 1/4" diameter, 3/4" cut depth, 2-3/4" total length
- Carbide, Titanium Nitrade Coating,
- 4 flute / centercutting / Upspiral
The high pitched sound that we had experienced the first day definitely decreased, most likely due to the shorter passes. But the shorter passes and increased IPM was an enormous improvements on the deeper passes. While it takes 3 passes now, going at 80+IPM slowest we have great improvements on speed.
One Problem: The bit is an upspiral bit, yet it fails to remove the mdf dust from the 1/4" width channel. The dust accumulates and causes the high pitched noise to increase. The dust collection has no effect on the dust so we were just going to use a small shop vac and do it between passes? Any suggestions?
I'm really excited for the CMT bit, I hope it increases the cut speeds. Is it a compression bit, it didn't say?
