587,012 active members*
3,458 visitors online*
Page 83 of 88 33738182838485
Results 1,641 to 1,660 of 1750
  1. #1641
    Aug 2004
    3215
    Its great to be able to go see someone machine that is built and see it run in person. You have to love the DIY world.
    Joe
  2. #1642
    Aug 2007
    6
    Just thought I'd throw this out there and see if there are any CNC'ers near Portland, OR who could cut out the MDF for my Joe's 2006?
  3. #1643
    May 2006
    954
    Joe is still cutting kits for the 06 in addition to the 4x4, just email him.
  4. #1644
    Aug 2007
    6
    Excellent, I thought he wasn't doing the 2006 anymore.
  5. #1645
    May 2006
    954
    Sure is, I believe he still cuts a few kits a month for the 06, they are still popular.
  6. #1646
    Feb 2006
    8
    Gordon, John & Jim
    Drop me a note at [email protected] with contact information. The weekend will be better then the a week day evening. I'm just south of 66 near New Bradick and 28 in Centrevill
    Yep, I still have the half of the 1/2 x 8 TPI x 2 start (18" or so) plus other odd ball left overs, over purchases - 10 or 15 1/2" spring nuts and some 1/2 bolts ( 1 or 1 1/2" IIRC).
    Tony
  7. #1647
    Nov 2008
    12
    Nice!
    I am interesting in your design. I think it will work. If you start to build this model, please imform me and show me.
  8. #1648
    Feb 2009
    Dimensioned PDF Plans?
    Would anyone care to email me a copy of their dimensioned plans in pdf format of the 2006?
    FYI, I have all the other files from cnczone.com that have to be dimensioned thru CAD software?
    If I could figure how to use the CAD software, I could design my own.
    Most CAD software only supports xp pro or above and I have win98.
    In other words, I am looking for a set of plans that are already dimensioned and easily printed like JRGRO did with his plans.
    Since I currently do not have a CNC router,
    I might be interested if a person would fabricate the mdf parts for a nominal fee.
    email me : rzerk at usa dot com
    thanks
  9. #1649
    May 2006
    954
    Joe is still cutting 06 kits you should send him an email. There aren't dimensioned plans persay but there is a PDF and autocad drawings for the machine and parts to be cut and machined.
  10. #1650
    Nov 2008
    12
    CAD software
    Hello rzerk
    You can use Auot CAD 2000 and 2002 software with your window. if you want some pdf file, I can give some pdf.
    mail me at
    [email protected]
  11. #1651
    May 2009
    264
    Joe,
    Are you still selling the kits? If so what is in the kit. Is it the MDF and HDPE parts only? Does it include the aluminum angle (drilled and tapped)? I have to assume it doesn't come with the pipe since you can get that just about anyplace.
    How about all the hardware, bearings and what not?
    Matthew
  12. #1652
    Jun 2009
    7
    HAR THA, can you email me the .pdf at [email protected] please, i'm also wondering what comes in the kit for the 06 if anyone knows.
  13. #1653
    Jul 2003
    9
    Looking for Info
    Hi All:
    This is my first post here--but I've been lurkiong for a year or so.
    I have built a "Lionclaw" Router (works well) --similar in most respects to Joe's, but a bit lighter duty. I have a "Skew" problem. Did a "345" check and have noticable error--I remember that somewhere in this Thread, there is a technique for coping with this problem--but I can't find it.
    Does anyone know how I should go about "Squaring the Axies" or can lead me to the Posts Discussing it???
    Thanks very much
    John Bell
    Oakville Ontario
  14. #1654
    Sep 2007
    36
    I think thus is the one you are looking for.
    http://www.cnczone.com/forums/showthread.php?t=51485
    Mike
    I live in my own world, but that's ok they know me here.
  15. #1655
    Jun 2006
    106
    Quote Originally Posted by rzerk View Post
    thanks
    why are you still using 98 ? not knocking you just curious. I use it on my mill control computer as it is the last version that allows me to go to DOS directly as I have no figured out the whole dual boot thing yet. (that and I am stuck on turboCNC )
  16. #1656
    Feb 2007
    138
    I'm going to cut the parts for a Joe's 2006 kit for a friend of mine (using my own 2006... that I built from Joe's kit). I located the .dwg files, converted them to .dxf, and have them almost ready to cut... using Vectric Cut2D.
    But I can't locate anything that has dimensions for the depth of cut (for the various slots, pockets, etc. that don't cut completely through the material.
    Does anybody have some idea where to find these "Depth" dimensions? I suppose I can try to measure the parts on my own machine... but it would be nicer to have the actual numbers....
    Thanks!
    -Taylor
  17. #1657
    35538
    I think you can measure them in the free Solidworks viewer, if you download the Solidworks model.
  18. #1658
    Feb 2007
    138
    Thanks Gerry,
    I'm embarrassed to admit that I never looked at the Solidworks model while I was building my machine. It would have been SO helpful... if I had only known about it.
    Now... I've got the free eViewer, and can look at the whole machine, or individual components, can rotate them in space, in side, top, bottom views, etc... but I'm darned if i can figure out what it takes to activate the "measure" tool... under the Tools menu.
    No matter what I try, the "measure" tool stays grayed out. What am I doing wrong?
    Thanks!
    -Taylor
  19. #1659
    35538
    I've never tried it, so maybe I'm wrong, and you can't measure it?
  20. #1660
    Aug 2004
    3215
    ok found this in an old email, this will help some.
    here are the pictures with areas marked.
    yellow = 0.15" from surface (deep)
    red = 0.25" from surface (deep)
    blue = is all way through.
    Attached Thumbnails Attached Thumbnails Parts-1 11-02-06a.jpg   Parts-2 11-02-06a.jpg
  1. Two more of Joe's CNC Model 2006
    By JLT in forum Joes CNC Model 2006
    Last Post: 01-31-2019, 02:27 AM
  2. [AU] Joe's 2006 Model
    By nat.andrews in forum Joes CNC Model 2006
    Last Post: 11-11-2013, 11:50 AM
  3. Electronics for a Model 2006
    By joegtp in forum Joes CNC Model 2006
    Last Post: 08-31-2011, 04:43 PM
  4. New to Joe model 2006
    By Darroll in forum Joes CNC Model 2006
    Last Post: 01-16-2008, 11:31 PM
  5. JOES cnc MODEL 2006 R-1 or R-2???
    By Khalid in forum Joes CNC Model 2006
    Last Post: 11-11-2007, 06:58 PM
