Hi ! I am new at this so please bear with me
I am looking to drive a single servo motor. What i need to do is rotate a circle every 12 inches (circumference) all i need to do is hook up a single button, when pushed it rotates the circle 12 inches then stops, push again and it repeats the process. One direction only.
If you can assist me with the most simple way to achieve this, it would be appreciated. Even if there is a way to do this without the use of a servo motor. I chose a servo motor because of the strength, it needs to be high horsepower for the application, more or less a feeder system.
Thank you!
