586,655 active members*
3,562 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Cracked air filter sight glass on VF-3
Results 1 to 6 of 6
    Feb 2006
    49
    The air filter/regulator on our VF-3 has a crack in the plastic sight glass and is leaking air. Do you know who might sell the replacement part? I’d prefer to just buy the window if possible to save money. Data below.
    parker 06e1c00017p
    installed on:
    Model # vf-3d
    Sn 21873
    Doug
    Feb 2007
    381
    We had one do that on our SL-10. Unfortunately, finding someone who sells parts is extremely difficult. We ended up buying the whole regulator for ours. I seems silly, I know. But if you consider a shop rate of $40/hr, if you spend 2 hours looking for the part, you burned $80. You can darn near just buy a regulator for that. Good luck to you!
    :cheers:
    Mike
    May 2004
    4519
    I think I found a source for this for someone months ago, but I do not have time to dig through the old posts to find it and do not recall the information.
    Start here: http://www.parker.com/portal/site/PA...ult06e1c00017p
    Feb 2006
    49
    I agree, a new one is 40$ so I will probably just buy one to save time. I emailed Parker mostly out of curiousity and did get a reply that my request was being sent to the proper department. It will be interesting to see if they can help and how long it takes.
    It does bother me to replace the entire thing for a little plastic window. I think I will buy a new one and replace the window on this one with a metal plate and use it on a future project.
    Thanks for the advice.
    Feb 2006
    49
    I did get a response from Parker about 24 hrs after my inquiry and they want 80$ for the entire bowl and do not sell the glass alone (details below). The local Haas dealer never responded to my email. I plan to buy a new filter/regulator for about $40 from McMaster.
    Doug
    William,
    This sight glass alone is not offered, you will need to purchase a complete
    replacement Bowl kit. part # PS723P
    List $ 80.40
    Please contact a distributor in your area to place an order.
    Feb 2007
    381
    Yeah. Definitely not like it used to be.
    :cheers:
    Mike
  1. *NEWBIE* Power Line filter (Transformer vs. Filter)
    By cjchands in forum CNC Machine Related Electronics
    Last Post: 09-26-2009, 02:36 AM
  2. Cutting polarizing filter glass
    By MechanoMan in forum Glass, Plastic and Stone
    Last Post: 02-05-2009, 05:51 PM
  3. RFQ - Rifle Sight
    By Flatnick in forum Employment Opportunity
    Last Post: 11-13-2007, 07:23 PM
  4. 3D image "cracked" inside glass
    By moyesboy2 in forum Glass, Plastic and Stone
    Last Post: 08-04-2006, 07:42 AM
  5. Cracked casting?
    By wyobmf in forum Bridgeport / Hardinge Mills
    Last Post: 07-25-2006, 06:13 PM
