586,075 active members*
4,224 visitors online*
    Apr 2011
    73
    How Do I Wire This Power Supply?
    I ordered this power supply:
    350W 30V 11.5A Switching Power Supply Radio LED Charger US3
    Unfortunately, I don't know how to hook it up. It has 9 places to connect wires. The label looks a little like this:
    | +V ADJ | +V |_ _ -V _| +=+ | N | L |
    --------- 1 2 3 - 4 5 6 ---7 --- 8 --9
    The +=+ symbol is actually three horizontal lines that get smaller as they go down and it has a vertical line above that in the center. I think its the ground symbol.
    Anyway, could you please tell me what goes where. I am trying to hook it up to a small controller board. Where does the 120V go in and where does the 30V come out?
    Thank you
    Oct 2005
    58
    The +V ADJ is for minor adjustment of the Positive 30 Volts.
    1 2 3: +V is the Positive 30 volts out three terminals 30 volts each.
    4 5 6: -V is the negative or ground (return) for the 30 volts three terminals.
    7: That is a grd. (earth ground) symbol. This is where your green wire (US)
    connects to ground all metal cases. The round terminal on the plug that plugs in your outlet.
    8: N is the neutral return (white wire) connection. This is the large or wide spade of the plug that plugs in your outlet.
    9: L is the 120V load (black wire) that connects to the small terminal or spade of your plug that plugs in your outlet
    Harold
    Apr 2011
    73
    That is exactly what I need!
    Thank you
  1. FLA-100 - 48 Power Supply Wire Gauge
    By Darylb in forum DIY CNC Router Table Machines
    Last Post: 11-18-2011, 01:41 AM
  2. power supply for 2mm hot wire
    By aaabeee in forum CNC Wire Foam Cutter Machines
    Last Post: 09-05-2011, 04:04 PM
  3. My New Power Supply for Wire
    By indycraft in forum CNC Wire Foam Cutter Machines
    Last Post: 05-21-2011, 07:23 PM
  4. Manual Hot Wire Power Supply
    By jimdaug in forum CNC Wire Foam Cutter Machines
    Last Post: 01-16-2011, 09:57 PM
  5. power supply size? for multi wire (total 250 inches of wire)
    By DanOSB in forum CNC Wire Foam Cutter Machines
    Last Post: 03-02-2009, 11:34 PM
