586,071 active members*
4,360 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > cann't clear estop alarm after 4th was removed
Results 1 to 11 of 11
    Apr 2010
    260
    I hit the estop and turned off the HRT210 setting in the controler. Then I disconnected the HRT cables. Now the estop alarm wont clear out. I tried reconnecting the HRT but that did not work.
    Any ideas on what has happened?
    www.machmachine.com
    Jul 2005
    12177
    Did you turn the machine off. Somewhere I have seen a warning that the rotaries must be connected or disconnected only when the main power is off.
    Mar 2010
    1852
    I don't mean to insult anyone here, because I don't know your experience level, but just wanted to make sure that you knew that the E-Stop button has to be turned to release it!!!!!
    In addition, make sure that the 4th axis setting actually says OFF.
    Otherwise, I would just power down and restart.
    Mike
    Jul 2005
    12177
    Quote Originally Posted by Machineit View Post
    ......the E-Stop button has to be turned to release it!!!!!........
    Discovered that one years ago.
    Mar 2010
    1852
    Quote Originally Posted by Geof View Post
    Ya, me too! It is a button that is really not used that much and you can forget that about it.
    Mike
    Apr 2010
    260
    we we got it. Its always the dumbest things. The coolant pump cable was half way pulled out. Must have happened when we were disconnecting the HRT.
    thanks anyways!
    www.machmachine.com
    Feb 2010
    1184
    Quote Originally Posted by dingo0722 View Post
    thanks anyways!
    That should not generate an E-Stop condition.
    Aug 2009
    235
    ... Its always the dumbest things...
    No, I think not turning the e-stop button would be the dumbest thing.
    Feb 2009
    6028
    I have had 4 service calls in my history.
    Customer - I have an alarm, emergency stop
    Me - have you tried all the estop buttons. Look around some machines have more than one
    Customer- oh ya, I'm not stupid you know.
    Me- is the machine overtraveled.
    Customer-no its xxxx
    Me-be there in an hour/day whatever
    Me-emergency stop was pressed on chip conveyor/atc unit/remote pendant
    Customer- oh, I didn't know there was one there
    Me-minimum charge, sorry. Any other problems while I'm here.
    Customer- embarrassed .
    Happens more than you think.
    Mar 2010
    1852
    Come on guys, fess up, come on!!!!!!
    Apr 2010
    260
    Quote Originally Posted by haastec View Post
    I agree. But all I did was reset the coolant pump cable and the alarm cleared. no idea then.
    www.machmachine.com
  1. Mazak MYSTERY. HOW do you clear this ANNOYING Mazak alarm??!!! NOBODY KNOWS!!
    By Mill&Lathe in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-03-2022, 01:55 AM
  2. Replies: 3
    Last Post: 06-18-2009, 09:13 PM
  3. cann't get a lead in or out.
    By jz25180 in forum Mastercam
    Last Post: 06-08-2009, 02:11 AM
  4. sl20 alarm 144 help need to clear
    By mkmk123 in forum Haas Lathes
    Last Post: 11-23-2007, 06:48 PM
