586,358 active members*
3,643 visitors online*
    Aug 2007
    12
    help identifying turning insert
    any one know what type of inserts these are? i got the tool holders from a friend but he cant remember what kind of inserts they are.. any help is appreciated!
    the shank is .364 square
    Aug 2007
    6
    I believe we have some of those at the shop. I will check tomorrow if you still need the info.
    Aug 2007
    12
    thanks for the post but i ended up getting another turning kit for fairly cheap.. never found out if seco still makes the carboloy line either and ended up scrapping them once i got the new kit in..
    Jan 2011
    id insert
    go to Carbide Depot Carbide Inserts and Cutting Tools
    rummage around until you get to the insert id page - probably under technical info. You probably have something like tnmp 321 or tpgt 321...it will be clear when you see chart there...
    one source of the inserts is ebay....buy us brands, not "generic"
  1. Preferred choice of insert for Aluminum turning
    By buffaloguy in forum Material Machining Solutions
    Last Post: 04-01-2018, 03:25 PM
  2. Replies: 2
    Last Post: 01-13-2011, 02:19 PM
  3. insert grades for turning/drilling tungsten
    By claya in forum MetalWork Discussion
    Last Post: 06-28-2010, 07:15 PM
  4. Need help identifying
    By pflynnjr in forum Stepper Motors / Drives
    Last Post: 04-18-2007, 05:58 PM
  5. Help identifying this please
    By studysession in forum Uncategorised MetalWorking Machines
    Last Post: 12-05-2004, 08:40 PM
