:argue:
Hello everybody,
Does enyone know a link or something to download the programming manual of a Moriseiki CL25 lathe?
Thanks a lot Bro's
:argue:
Hello everybody,
Thanks a lot Bro's
David,
What type of control does this machine have? It should say over the TV screen where you can see the program running.
MSC-518
Sorry 4 the delay
So, you need a fanuc 18T programming manual. I'm sure someone has a PDF. My email won't let me send large files over 30mb..,,
David did you ever locate a Fanuc 18T manual? Not that I can help you out...I am searching myself. Thought maybe you could point me in the right direction.
:violin: no havent =( ..... I decided to learn how to live with out it
What questions do you have that you think would be answered by the manual?
a lot !!
for instance I want to know how to tap a hole
You will have 2 possibilities depending on the control and what options have been enabled/installed:
1)
G01 Z-1. F0.05
M05
G01 Z0.3 M04
M05
2)
G84 Z-1. F0.05
I am trying to set up using live tooling and second spindle. I am assuming the second spindle will be axis B. After setting Z0.0 and making chips when using one spindle, I am lost. The live drill will be drilling when the part is in the second spindle, so do I touch off the drill to face of part in spindle 2, take # from machine position page and put it in Z offset for drill? I have to get the part to the second spindle first and don't have a clue.
I do have the Fanuc 18T manual (all of them Programming, Connection, Maintenance). PM if you still need it.
i need help with mori seiki tl-1 i need help it shows blackscreen wit red led on the power unit .
where can i find a manual for mori seiki tl-1 it shows no screen
If it doesnt show anything on the screen and doesnt show any red leds on the motherboard, even if the red led of the power supply is lit, it is likely a problem with the power supply. If the red leds on the motherboard light up then you should look at them and do the troubleshooting acordingly.
Yasnac or fanuc? What model? Tl1s are pretty old, I've even seen them with pixie tube displays.
Could i have these manuals please of course only if you still have them, thx
