When I drill on a manual mill, I am able to pull a continuous chip. On the Tormach, I often get these small broken chips. Sometimes these chips cause clogging or rubbing, so the hole turns out bellmouthed or oversize. Specifically, I am talking about using a .100 drill, running 5k rpm (or a bit less) in aluminum and feeding at 10 ipm or a bit more or a bit less. That should give about the right chip load for drilling. Is the problem that the Z step rate isn't smooth enough relative to the time it takes for the drill to make one rotation?
When I use a larger drill like 3/8 I am able to pull a continuous chip just fine.
I use flood coolant in this case.
