I have been trying to get the chamfering setup to work but have been unsuccessful. I have a .5" diameter endmill with a 45 degree chamfer on it. I have been trying to put a .030" chamfer around a hole but I can't seem to get it to work. If I try to change the depth then it seems to go and make the hole wider. It seems to look like it is doing everything correctly on the simulation but when it does the machining it doesn't come out correctly at all.
