586,608 active members*
3,659 visitors online*
Results 1 to 8 of 8
    Apr 2012
    21
    Power and speed settings for Chinese Laser
    I hope I am putting this post in the right spot. My apologies if it is not.
    I have just purchased a 120W Hurricane Laser. It should be arriving at the end of the month. I am trying to learn as much as I can before it arrives.
    Does anyone have a list of speed and power settings for different materials for both raster and vector? My in laws have a 35w epilog and it came with such a chart. Any thoughts or references?
    Thanks in advance!
    Nov 2011
    I usually start here...
    Synrad's Laser Processing Calculator
    Your machine will have the input in mm/sec, so you may need to do a little math. I keep a text document on my desktop that I use to record settings as I go, so I have some reference to go back to. You'll quickly get a feel for it, and be able to fine tune from there.
    [email protected]
    if the laser machine coming with CO2 tube, this is suggestion on power and speed.
    [email protected]
    skype:ms.leizhang www.wklaser.com
    Apr 2012
    21
    Quote Originally Posted by GWEIKE-LASER View Post
    Thanks for the info! Laser will be here tomorrow and look forward to trying out these settings.
    Apr 2012
    21
    Do you happen to have settings for engraving as well? A good starting place would be nice.
    JENNY from GWEIKE LASER
    we usually set the engraving speed on 400-500mm and the power in 30-50.
    To engraving slightly, the speed can be faster
    To engraving deepm the speed can be lower and power a bit bigger.
    you can set the speed and power accoring the depth you want.
    [email protected]
    Apr 2012
    21
    Isit possible to put a collimating lens on my 150 Watt laser. If so, Which one would you recommend. We are having a problem with our honeycomb not being level. When we focus the laser in one spot it cuts fine but when the beam gets to a part of the table that is higher it does not cut through.
    Jenny from GWEIKE laser
    Quote Originally Posted by cdmcali View Post
    Suggest you choose 63.5 or 100mm distance focus lens.
    Try use the bigger power and lower speed
    for the honeycomb problem, is it possible put some part under honeycomb and make them in same level? This is really big problem to cause different cutting effection in different place
    [email protected]
  1. cut speed / power settings / air pressure
    By marcmnrsports in forum Waterjet General Topics
    Last Post: 06-09-2011, 03:22 AM
  2. Tips for determining power/speed settings?
    By tdiaz in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-05-2010, 07:37 PM
  3. Chinese laser. power suggestion
    By salmve in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-30-2009, 09:36 PM
  4. Color laser power settings for B&W image
    By millennium07 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-24-2009, 09:46 PM
  5. Co2 Laser cutting guide or PDF for different power settings and speed
    By WooDe in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-07-2008, 09:24 PM
