586,108 active members*
3,069 visitors online*
    Oct 2011
    Heidenhain iTNC530 touch probe problem
    Hello there!
    I'm trying to calibrate the length of my TS640 Heidenhain touchprobe using iTNC530 controller.
    The X and Y axis are no problem, (using a ring of calibrated radius), but the length (Z axis) won't work. I don't know what I am doing wrong.
    I'm using the manual, 2.2: calibrating a Touch Trigger Probe.
    This manual says:
    - Set the datum in the spindle axis such that for the machine tool table Z=0
    - Go to touch probe Cal L soft keys
    - Enter the tool axis (Z in my case)
    - Datum: enter the height of the ring gauge: (30 mm in my case)
    - The menu items effective ball radius and effective length do not require input
    -move the touch probe to a position just above the ring and gauge
    -to probe the upper surfacce of the ring gauge, press the machine start button.
    I did all the above things.
    So first I set the datum z=0 using the touch probe, by touching the table
    Then I go to the Cal L menu:
    And I entered datum:30 for the height of the calibration ring.
    Next thing I do is to touch the ring top:
    The effective length is now changed.
    Next I press: enter length in tool table
    This length is indeed entered in the tool table:
    BUT NOW THE PROBLEM:
    To check if the calibration is correct I retouch the table and this is now again z=0, OK correct. Then I touch the top of the ring: Z=+30,, correct again!
    BUT the position mentioned by the controller is incorrect. After touching, the tool always retract x mm's (let say about 10 mm), so after setting the datum the actual position should be about -10mm, but instead it's always in the order of -150 mm. So the position is incorrect.
    Anyone any idea?
    Oct 2011
    FYI: The machine also has a Blum laser measurement system to measure the length of the tools.
    What I don't understand: how does the controller knows the length of the touch probe? It measures the difference between the table and the top of the ring = 30 mm, but how is it possible to extract the tool length out of that?
    Dec 2011
    99
    Negative effective length?
    Effective length determination step by step:
    - TOOL CALL 0 Z (Length = 0)
    - The empty spindle (Length = 0) to set the zero point Z
    For example:
    Display: ACTL. Z=70!
    - TOOL CALL 1 Z (TS641)
    - CAL L softkey
    Tool axis = Z
    Datum = +0
    Z- softkey
    The effective length of the actual length of TS641 now (approximately +140 mm)!
    - The measured effective length of the tool table can be entered!
    Have a nice day!
  1. HEIDENHAIN iTNC530
    By aliaghaei in forum Drilling- and Milling Machines
    Last Post: 09-10-2018, 07:52 PM
  2. Heidenhain TS-112 touch probe
    By rooj65 in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 12-24-2017, 10:01 AM
  3. need postprocessor for hypermill to heidenhain itnc530
    By stripper in forum Post Processor Files
    Last Post: 07-17-2011, 10:18 AM
  4. Heidenhain iTNC530
    By Jay Roy in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-07-2011, 06:31 PM
  5. Heidenhain iTNC530 First StartUp
    By Leha_Blin in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-29-2008, 06:30 PM
