586,630 active members*
2,561 visitors online*
IndustryArena Forum > MetalWorking Machines > OKK > "B" Axis Break Issue
    Aug 2008
    We have 4 OKK HM1250 Machine centers. Two of them have issues where when rough milling the "B" axis will actually lose positon...the mill will actually push the axis around. Has anyone else had this?? Anyone know ofa fix other than lighter depths of cut...or lower feedrates??
    Oct 2008
    29
    Re: "B" Axis Break Issue
    Does the B axis gets clamped after positioning to a certain angle, before the heavy cutting / rough milling is commanded? If no, then Try clamping B axis. Other possible reason could be the B axis worm gear has backlash and it needs to be corrected.
    Quote Originally Posted by diesel68 View Post
  1. Common Laser Problems and Solutions(1) - Y Axis movement issue on "Test"
    By Gweikelasers in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-22-2016, 10:45 PM
  2. Replies: 3
    Last Post: 06-25-2014, 03:51 PM
  3. Replies: 17
    Last Post: 02-22-2014, 06:58 PM
  4. X Axis "Goes Off Pattern", "Awry", "Skewed", "Travels"
    By DaDaDaddio in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-06-2013, 09:59 AM
  5. Replies: 4
    Last Post: 12-17-2011, 04:27 PM
