586,058 active members*
4,285 visitors online*
Thread: new to mach3
    Jan 2011
    51
    new to mach3
    Iam having trouble in my set up.Iam sure its a dumb mistake on my part but please help if you can.Is there a easy way to set up my machine boundary's? I set up soft limits and I cant get them to stay.And when I change my absolute to where I want it wont enter?What am I doing wrong.If theres a easy step by step way to set these it would sure help me out.Thanks
    Do you have home switches? You can't use softlimits without home switches.
    What do you mean when you say "change my absolute"?
    Jan 2011
    51
    help
    I am putting my home /limit switches on now I just finished the x and starting on the y.I will wire them after there all mounted.I am using 1 switch for limit and home and the other for the limit in the other direction.When I say absolute I mean the far limit in each direction of travel.Like on the diagnostic page it has absolute in the top right corner of the screen.It has min and max absolute cord.I could be misunderstanding that. Please explain it to me as I need to learn and there's no one around me that knows what mach3 is!
    That abs on the Diagnostics page basically just displays the limits of a loaded g-code program, plus the current location if it's outside the program limits.
    Load some g-code and you'll see it change.
    I never knew it was even there, and honestly, don't know what it's purpose is.
    My recommendation is to go to the machsupport site and start watching all the tutorial videos. Then watch them again.
    Jan 2011
    51
    help
    Thanks Gerry,I will hit the videos.
  1. other than mach3
    By blackice in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-01-2011, 02:40 PM
  2. Differences Between Mach3 Mill and Mach3 Plasma?
    By cjjonesarmory in forum Mach Plasma / Laser
    Last Post: 11-18-2010, 04:12 PM
  3. Using Mach3 with Reprap extruderUsing Mach3 with Reprap extruder
    By router101 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-03-2010, 10:46 PM
  4. MACH3 ONE TO ONE.....
    By MACH DESIGN in forum Mach Mill
    Last Post: 04-27-2008, 02:05 PM
  5. want to see what mach3 is doing
    By mike hide in forum Mach Mill
    Last Post: 03-03-2008, 08:31 PM
