586,106 active members*
3,327 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Quick Question On Cooling Stepper Motors
    Mar 2008
    81
    Hi People,
    Just wondering if there would be any advantage of Water or Air Cooling My Stepper Motors??
    I have yet to finish my machine but was thinking the other day that people say that stepper motors get a little warm so i thought of these 2 ideas and wondered on what other people think.
    Idea 1. is to make like a open ended box type thing to incase the stepper motor and have water pass thought it, kinda like a water jacket, as i will have water running thought my spindle motor and the pump i'm using has to much flow for it so could be good to use the extra water for this if people think it is a good idea.
    Idea 2. is to make a cover and use a fan on the end to blow air over the stepper to keep it cooler, easyer but just putting these ideas out there for peoples opitions.
    Thanks for reading and replying if you do
    Will.
    1695
    I don't use either. The motors don't get too hot when mounted solidly to a metal frame that acts as a big heat sink. The cooler the better, but I think the fan idea is more than enough.
    Oct 2005
    2392
    They are designed to run well even when "hot". I like to keep them under 55'C which is about the point where it is painful to hold your hand on it (if you don't have a thermometer).
    As H500 has said they are designed to sink heat through the metal mounting plate, which for size23 motors should ideally be about 10mm thick metal (3/8" thick).
    Mar 2008
    81
    Sounds good
    Thanks for the info guys i will just see how they go first then work out if i need to cool them or not.
  1. Cooling Small AC Motors
    By 2_many_hobbies in forum Benchtop Machines
    Last Post: 02-19-2010, 06:00 AM
  2. Quick PSU/Stepper question.
    By idtkid in forum DIY CNC Router Table Machines
    Last Post: 01-30-2009, 04:37 PM
  3. Real quick Gecko/stepper question
    Last Post: 01-27-2009, 05:22 PM
  4. Quick Question on stepper motors
    By cspearsall in forum Open Source CNC Machine Designs
    Last Post: 06-28-2006, 11:51 AM
  5. quick stepper electronics question
    By keebler303 in forum CNC Machine Related Electronics
    Last Post: 04-01-2006, 02:40 AM
