586,082 active members*
3,703 visitors online*
Thread: haas vf3
Results 1 to 6 of 6
    Apr 2012
    6
    haas vf3
    when i turn machine on i get low voltage alarm and overvoltage alarm for about 10 minutes before i can clear them and run!1 then latter in day i get overvoltage alarm!!any help
    Apr 2010
    20
    I would check the voltage for each of the 3 legs (3 phase). they have to be within a certain range. I think the manual tells you the range. are you using a phase coverter by chance?
    myspace.com/1metalmorphose
    Apr 2012
    6
    haas vf3
    no phase converter worked fine for years11maybe board or somethingg going bad?
    May 2004
    4519
    Or you have a bad incoming transformer. Or bad wire insulation leaking voltage to ground. Just start with the basics and measure the voltages.
    Mar 2008
    95
    sounds like bad vector drive. watch the diagnostic screen page two for vector drive volts when you first start it up probably reads real low and slowly climbs until the alarm clears until finally topping off at approx 325VDC. nothing you can do but deal with it or replace vector drive
    Nov 2005
    56
    It's a wonky vector drive.
  1. Replies: 2
    Last Post: 04-03-2012, 04:31 PM
  2. haas SL-20 to Haas bar 300 alignment plate needed
    By J-Mccoin 2009 in forum Haas Lathes
    Last Post: 12-03-2009, 04:13 AM
  3. RFQ haas SL-20 to Haas bar 300 alignment plate needed
    By J-Mccoin 2009 in forum Employment Opportunity
    Last Post: 10-28-2009, 08:17 PM
  4. Haas Super Mini-Mill and Haas Trunnion Table
    By Gabe Newell in forum Haas Mills
    Last Post: 06-07-2009, 07:23 PM
