586,094 active members*
4,137 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Servo driven machine, do I have to put steppers on it?
Results 1 to 8 of 8
    Oct 2004
    198
    I have a servo driven machine that is knackered (software), if I want to run the Mach software (which I just setup on a router and I love it) will I need to remove the servos and encoders and install steppers?
    Or is there a way to run the servo motors and just change the drives?
    Damn it's good software.......
    Feb 2004
    18
    Depending on the specs of your servos and encoders, you may just have to replace the servo amps (drives) with a version that takes Mach x step and direction pulse outputs.
    Look at Rutex or Gecko, both are good drives, have good support and lots of info on this and the yahoo forums.
    Aug 2004
    2849
    not if you're using step/direction drivers as mentioned above.
    Oct 2004
    198
    Thanks guys, just for your info the motors are siemens HU5042-0AF01-Z, I know I'm leaning towards steppers because of the ease of setup, but if you think that running the existing servos with gecko drives wouldn't be too bad I might purchase one gecko drive and give it a go. (I can't tell what voltage the motors are though)
    I would like to have encoders so the existing servos would be good for that, also I don't have to mount new motors.
    As you can see I am arguing with myself.....
    Oct 2004
    198
    In theory should something like one of these Gecko boards be adequate to run?
    http://www.geckodrive.com/product.cfm?pid=17
    The machine is 6 axis, would a board like this work or should I buy seperate drives similar to these?
    http://www.geckodrive.com/product.cfm?pid=13
    I think maybe I should send Gecko a pic of the label on the motor and they can tell me, unless you guys can.
    The G101 (or G100, G-Rex) is not a motor drive. It's a step generator and I/O board. Mach4 will be able to control it, but it's in Alpha stage right now.
    The G320 is the servo drive. Yes, ask Gecko if it will work for you.
    Oct 2005
    215
    Why not talk to rutex (www.rutex.com) they are in your area. They have drivers up to 200v and 40amp.
    Oct 2004
    198
    Thanks guys
