I have a 150W laser cutter and somebody has asked me if it was capable of cutting plywood. What are your experiences with laser cutting machines and plywood? Is is possible or is it a no-go? What power is needed for which thickness?
Not that this is going to help much. But, I have a 40w laser and am cutting up to 1/4" plywood in one pass. It requires full power and a very slow speed. Plywood is a little difficult for my machine as it depends on how much of the bonding agent is used in the construction of the plywood. But, yes, you can cut plywood.
Milt
Yes it will cut plywood.
How thick? Depends on the quality you need. Guys making steel rule dies use 400W CO2 lasers to cut 1/2" and 3/4" plywood. They need straight sides. With lower power, you will end up with a tapered cut. Depending on what the cutting is for, it may or may not be acceptable. Just try it and see.
Matt
150W I could see you getting through 3/4". Whether the end product will be acceptable and if it's worth the time (I expect the machine to run pretty slowly) will be the real questions.
I'd buy a 1/4 or 1/2 sheet and test it out. It's worth the $30 to gain the knowledge.
150W can cut plywood. But too thick plywood can not be OK.
yes, CO2 laser can cut plywood,but for different thickness, the cutting speed is different.
Phone: +86-15550002101
MSN:[email protected] Skype: jqlaser31
Stay away from exterior type plywoods. The glues make it very difficult. Baltic Birch is one of the best for cutting by laser
Hi TurkishDelight,
We had cut 18-20mm 5-layers board by 150W Reci tube with 180W peal power. Yes no problem for 20mm plywood cutting.
Ms. Lucy 0086-18254116182
Jinan Quanxing Mechanical Equipment Co.,Ltd-CNC Router Machine,Woodworking Machine
Lucy (Jinan Consure Electronic Technology Co.,Ltd) 0086-18254116182
Web:http://www.jncslaser.com Email: [email protected] Skype:consurelaser
I suppose you can paint it black.
It's a heat element that is cutting. It's always going to burn. If you look at the edge, it's also far from straight.
Laser cutting is great for some applications and not so great for others.
1/4" is butter, 1/2" is a task. Much thicker than that and I won't even try.
It should be noted that cutting thick plywood is an extreme fire hazard. You will need a strong air blast to clear the kerf. If your air blast is not strong enough the effect is more akin to blowing on an ember to start a fire. Long deep cuts, combined with the fact that you probably won't make it through in one pass, channels that air along your cut keeping the burning going a very long time.
Adding that to the fact that plywood is layered and sometimes has voids or holes inside that you can't see makes for a very interesting afternoon with the laser. Ask how I know
If I were to do it again, I would not do it again. :tired:
Don't even try with the stock "fart cannon" oilless compressor that comes with your machine. That POS is akin to fanning a fire. If you must I'd have a sand bucket or insurance policy ready.
150W die board/ plywood laser cutting machine cutting thickness show:
15mm dieboard Cutting speed:4.5mm per second, 18mm die board cutting speed:4mm per second 20mm die baord 2.5 mm per second
Plywood cutting videos how
Attachment 256782
More infomation, please contact:
Web: china famous CNC cutting machine manufacturers Laser Solution - CO2 laser cutting machine, fiber laser cutting machine, CNC Router Machine, laser engraving machine
Attachment 268836
I know this is an old thread but thought i'd share my 3/4" plywood test cut. I did this on a Mitsubishi LV using a 1/4" stainless tech table. My piece of plywood wasn't perfectly flat so I used the control box to adjust the standoff as it cut, too high and a fire would start underneath, too low and the kerf suddenly got really big.
Hey Milt, I know this is in response to you pose from 5 years ago, but I had a question for you.
You said you have used a 40W laser to cut 1/4" ply, is that using air assist? What do you think the thickest plywood could be and still be able to cut it with a tube like that?
Thanks!
-Cole
1/4 plywood with a 40 watt is possible with very slow speed and full power and probably 2 passes.yes air assist
Hello! I’ve just finished my construction. I needed a large amount of high-quality plywood. I read the reviews and decided to order from these guys www.plyterra.com. The quality of plywood is just excellent and the price is reasonable. In general, I was very pleased. I advise it to everyone!
