586,655 active members*
2,436 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > equipment for surface coating metals, e.g. nitriding
    Aug 2011
    I'm wondering how people surface coat or treat their metal parts they fabricate in the machine shop. Maybe get a third party to do it? And how much would they cost? I suppose some kinda ion implanter oven sort of thing.
    Say you mill out your gear profile in some metal with the intention to hob or broach out gears. Lets say you want to coat this home-made tool so it has a hard coat, how will one do it? E.g. TiN coatings etc.
    May 2004
    4519
    First, your base metal will need to be hard enough and tough enough to do the intended job. This usually requires selecting the correct metal, machining it, then heat treating it. I would highly recommend outsourcing the heat treating process. The cost of a kiln and cost to operate one is fairly high. Same for coatings. For coatings, except for basic case hardening, the temperatures are too high and chemicals too costly. I think you can case harden some materials as low as 450 degrees Fahrenheit. Most case hardening will not penetrate more than about 0.020-0.040" deep. The cost of outsourcing heat treat and coating really depends on what is wanted and needed, and is also based on batch size. A single piece could potentially cost over $50.00. Or, 50 of the same pieces could cost the same $50, or $1 each.
    Nov 2007
    479
    You can do plating like nickel and chrome in a do-it-yourself application. Requires a submersible solution (electrolyte), a sacrificial anode (plating material) and electricity.
    Aug 2012
    I think it depends on the work and type and should be asked to them directly.
  1. Another question about TIN coating
    By tbaker2500 in forum MetalWork Discussion
    Last Post: 02-22-2012, 06:55 PM
  2. A bendable coating!?
    By diyengineer in forum Material Machining Solutions
    Last Post: 08-22-2011, 12:33 AM
  3. Coating MDF
    By justCNCit in forum WoodWorking Topics
    Last Post: 08-16-2010, 01:35 AM
  4. Cutter coating
    By surfit in forum MetalWork Discussion
    Last Post: 03-29-2010, 04:55 PM
  5. New to power coating and in need of help
    By mik32176 in forum Mass finishing equipment/media/strategies
    Last Post: 10-25-2006, 06:21 PM
