586,117 active members*
3,378 visitors online*
IndustryArena Forum > MetalWorking Machines > Novakon > NM-145 mach 3 profile
Results 1 to 9 of 9
    Apr 2012
    Can someone please post the .xml profile for the nm-145? I believe that mine is not correct and am having trouble getting a response from Novakon. My spindle will not work.
    Oct 2011
    61
    overrev,
    I sent you a PM
    Feb 2009
    51
    NM-145 Spindle issue
    Quote Originally Posted by overrev View Post
    In port/pins make sure that spindle is enabled. Of course, you knew that anyway!
    I will send you a PM with my config.xml which applies to the spindle controller board dated July 2011.
    Apr 2012
    Got a copy. Thanks for the help!
    Aug 2006
    8
    copy please?
    Could I have a copy of your file as well?
    Sep 2010
    72
    What is the latest date/version of the 145 xml? Its not on their website anymore. Steve or Krenovian if you could send me a copy of yours if you have a new one it would be appreciated (PM for my email). I want to compare it to mine to see what is different (mine is from spring 2011, but there were a few things that were not correct in it when I got it).
    thanks!
    Oct 2011
    61
    toddp and t300,
    I've attached two zipped .xml files. The NM-145 file is the one Khai sent me for my machine. It is titled "New Circuit Board Test 2012 Jan". the NM-145B file is the one overrev got. It's titled "Mach 3 Mill NM-145" and doesn't have an obvious date. The main difference I can find in the two files is the rapids speeds. The former is set for about half the speed that the latter.xml is.
    If the zipped files don't work properly send me your email address in a pm and I will send the unzipped files to you. In unzipped form they are the same size, but in the zipped form the NM-145B file is only half the size of the NM-145 file so there may be a problem with the zipped version.
    Curtis
    Attached Files Attached Files
    Sep 2010
    72
    thanks, got it
    Aug 2006
    8
    me as well. Thanks for your help!
  1. Replies: 3
    Last Post: 05-14-2010, 09:16 AM
  2. Servo Drive Card for Mach II / Mach III
    By umarcnc in forum Mach Mill
    Last Post: 02-21-2010, 09:37 AM
  3. Mach 2 Mach 3 Post Processor
    By IntarisiaQ4 in forum Australia, New Zealand Club House
    Last Post: 10-17-2009, 11:50 PM
  4. Confused: Mach Turn, Mach Mill, Mach 2/3 ?
    By CanSir in forum Mach Software (ArtSoft software)
    Last Post: 02-16-2007, 11:41 AM
  5. Moving to mach 3 need exact mach 2 screen
    By carlnpa in forum Mach Software (ArtSoft software)
    Last Post: 12-11-2005, 10:00 PM
