Can someone please post the .xml profile for the nm-145? I believe that mine is not correct and am having trouble getting a response from Novakon. My spindle will not work.
overrev,
I sent you a PM
Got a copy. Thanks for the help!
Could I have a copy of your file as well?
What is the latest date/version of the 145 xml? Its not on their website anymore. Steve or Krenovian if you could send me a copy of yours if you have a new one it would be appreciated (PM for my email). I want to compare it to mine to see what is different (mine is from spring 2011, but there were a few things that were not correct in it when I got it).
thanks!
toddp and t300,
I've attached two zipped .xml files. The NM-145 file is the one Khai sent me for my machine. It is titled "New Circuit Board Test 2012 Jan". the NM-145B file is the one overrev got. It's titled "Mach 3 Mill NM-145" and doesn't have an obvious date. The main difference I can find in the two files is the rapids speeds. The former is set for about half the speed that the latter.xml is.
If the zipped files don't work properly send me your email address in a pm and I will send the unzipped files to you. In unzipped form they are the same size, but in the zipped form the NM-145B file is only half the size of the NM-145 file so there may be a problem with the zipped version.
Curtis
thanks, got it
me as well. Thanks for your help!
