586,121 active members*
3,421 visitors online*
Thread: Missing M30
Results 1 to 14 of 14
    Apr 2012
    Missing M30
    Everytime I go to post my programs to my cnc the last line, and my M30 is missing. I cant find out what is going on. I use to send my programs to Predator 2009 and than to my CNC's from there and it worked fine. I just ugraded ti Gibbscam 2011.
    May 2004
    4519
    Upgrades can do that. Report it to your vendor.
    Apr 2012
    So it might not me anything that I'm doing wrong than?
    Apr 2012
    also is there anything I can try and look at so I can get up and running until morning? I've also tried putting an M00 in and it still wont send that. Thanks for the help!!
    May 2004
    4519
    Yeah. Uninstall the update. Go back to the older version. Then get your money back. Why did you update anyway? Did the newer version have some actual improvement or feature you needed?
    Apr 2012
    I needed 2 more seats so I went from gibbs 2009 to gibbs 2011
    May 2004
    4519
    Ok. And right now what is your money getting you? Frustration? Production delays? Wonder if your vendor will reimburse you for that?
    Feb 2011
    80
    Quote Originally Posted by txcncman View Post
    there are a number of improvements from Gibbs 2009 to Gibbs 2011 that make the upgrade worth it. Especially if you use Gibbs a lot.
    Apr 2012
    I've been using 2009 on the old computer to get by for now It will load programs that use the live tooling just fine so I'm thinking its something I'm doing
    May 2004
    4519
    Interesting.
    Jun 2003
    513
    Quote Originally Posted by skeeter21 View Post
    Is the last line and the M30 missing from the NCF file, or does it not make it to your machine controller?
    Apr 2012
    It's in the programs on the computer and when I process the file I check and everything is there but when I post the program its just not making it into the machine controler. It's doing it on all 4 machines
    Jun 2003
    513
    Correct me if I'm wrong, but from what I read in your post you don't have posting issues in GibbsCAM, instead you have communication problems with Predator.
    It sounds more to me like Predator is stripping the last line or two when you upload to the controller, or it stops there and doesn't finish. You need to check your communication settings in Predator, at the controller, or both.
    Also check your programs to make sure you aren't changing anything when you open them in Predator.
    Don't uninstall and go back to your earlier version of Gibbs.
    Sep 2009
    84
    Do you have the trailing % after m30?
  1. Am I missing something?
    By rigo430 in forum EDM Discussion General Topics
    Last Post: 12-19-2011, 06:30 AM
  2. I'm missing something.
    By moto52000 in forum CamBam
    Last Post: 11-09-2011, 06:20 AM
  3. What am I missing here?
    By Japazo in forum G-Code Programing
    Last Post: 07-30-2011, 12:23 AM
  4. What am I missing?
    By CNC_Monkey in forum G-Code Programing
    Last Post: 06-10-2011, 11:16 PM
  5. Missing .DLL???
    By CyborgCNC in forum Surfcam
    Last Post: 05-25-2007, 06:41 PM
