I'd like to make it larger model, as the dimensions of my cnc. How to divide the model into two parts, the X axis? I tried the command slice relief but this command is divided into relief in Z axis.
Make the model to the finish size you want then use the panel toolpath tool to break it up to fit your cnc
Gary
Beckwith Decor Products
ArtCam Reseller/Trainer, Custom tooling & Onsrud Dealer
[QUOTE=Gary-BDP;1102256]Make the model to the finish size you want then use the panel toolpath tool to break it up to fit your cnc
Gary
I tried to, I divided the terrain into two equal parts by two squares, as a limiting line and the command center set position moves from one square to another, but we make a mirror imag
In artcam2008 I have no command panel toolpath tool.
yes your right 2008 does not have that feature.In artcam2008 I have no command panel toolpath tool.
in that case you do what we use to do prior to the panel toolpath tool, draw a number of connecting vector rectangles and toolpath each rectangle separately.
don't forget you will need to adjust your origin for each rectangle
Gary
