586,358 active members*
3,448 visitors online*
    Apr 2006
    40
    Should I use LinuxCNC or grbl/arduino?
    I was trying to figure if I should go with LinuxCnc route or arduino. I have an old machine with printer port, and I have an arduino. Pro/con?
    Jul 2009
    419
    Dunno about the arduino. But depending on how old the pc is, just take lincnc for a spin using the live cd.
    I use a P4 1000 or similar which runs like crazy.
    Sven
    http://www.puresven.com/?q=building-cnc-router
    Mar 2009
    106
    I really have not understood the point of running these machines on low powered microprocessors when you still need a computer as a user interface and you give up so much functionality. If the size of the electronics is an issue, LinuxCNC runs great on Intel ITX boards. Same with the cost. I run LinuxCNC on a 10 year old computer I got for free. There are plenty of uses for Arduinos (I have several) but this is not one of them.
    Apr 2006
    40
    Thanks. I was just making sure I wasn't missing anything. I have started putting together the stuff needed for a linuxcnc controller.
  1. Which pp to choose for arduino grbl?
    By CptanPanic in forum Post Processors
    Last Post: 03-08-2021, 11:05 PM
  2. DIY L298N Controller with GRBL Wiring Question???
    By Rymanvw in forum DIY CNC Router Table Machines
    Last Post: 03-05-2016, 11:17 PM
  3. Anyone have GRBL running on Arduino Nano?
    By hondaman900 in forum Open Source CNC Machine Designs
    Last Post: 04-20-2015, 08:10 PM
  4. Can't start up LinuxCNC!
    By alank2 in forum LinuxCNC (formerly EMC2)
    Last Post: 05-13-2012, 05:06 PM
  5. Has anyone used linuxcnc to run multicam machines?
    By IsaacD in forum LinuxCNC (formerly EMC2)
    Last Post: 04-20-2012, 08:43 PM
