586,112 active members*
2,999 visitors online*
Results 1 to 12 of 12
    Apr 2012
    Doosan 220 lynx issue...
    Hi guys and gals.....
    im new here so please be gentle with me....
    i have a problem with said machine, al funtions fine but when i rapid to from last cut into doing other cuts it sometimes touches the job before it gets to position....this sounds strange but it kinda ignoring its rapid to position in favour of trying to cut material....i overcome it using dwells but having spoken to an engineer he assured me its a parameter issue and its some sort of time saver.....
    well i dunno any other way to explain. hope thats enough to go on.
    thanks in advance
    May 2010
    Is this a G76 cycle?
    2932
    It is a parameter issue. What model control is it? 0iTB, C or D or something else?
    IIRC, on the 0i's it's parameter 1601 bit 4 RTO.
    Apr 2012
    thanks guys....its not the g76 issue and it is a 220b lynx oi te
    is that how the parameter should look or will be at the moment???
    Thanks again
    2932
    Quote Originally Posted by enigma173 View Post
    Thanks again
    There is no 0iT-E.
    My guess is that 1601 bit 4 is set to 1 now. If you change that to 0, the problem you are experiencing should go away. This parameter is the same for 0iT-A to 0iT-D.
    Sep 2011
    6
    Yes it's corner rounding caused by the servo not finishing it's last move before the control starts reading and performing the next line. I'll dig out the parameters you need to change tomorrow if you still need them. Tends to effect the smaller light weight Lynx more than the Puma's. Let me know if you still need them (not sure how old the post is)
    Apr 2012
    Thanks Shamus.....will be most helpful.
    Sep 2011
    6
    I'm back in the shop tomorrow, I'll bring my notes home scan and email them over to you if you give me your email address. Your welcome to PM me if your not keen on having your email address on here.
    Apr 2012
    np its [email protected] thanks bud
    Sep 2006
    8
    use G09-exact stop
    or G61
    Jun 2016
    Re: Doosan 220 lynx issue...
    Some one help me with id od chucking in doosan Lynx 220 pls,
    Sep 2007
    13
    hi , i had something similar, fixed it by putting another line in before the rapid to position , 1 mm away from where u want to go , worked 4 me
  1. Please Help Doosan Lynx 220 LM
    By norkis2006 in forum Daewoo/Doosan
    Last Post: 03-22-2014, 02:36 PM
  2. lynx doosan 220
    By tpsimer in forum MetalWork Discussion
    Last Post: 02-08-2014, 06:27 PM
  3. Doosan lynx 220lm
    By mattlynx in forum Uncategorised MetalWorking Machines
    Last Post: 02-02-2014, 11:11 PM
  4. New Doosan Lynx Questions
    By chucker in forum Daewoo/Doosan
    Last Post: 11-05-2012, 01:21 PM
  5. Doosan Lynx 220
    By Schljuutene in forum Daewoo/Doosan
    Last Post: 02-12-2010, 06:44 AM
