586,103 active members*
3,637 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > Importance of CAM for precision work
    Aug 2011
    Are all CAM software and file types the same as far as precision work is concerned?
    Obviously STL files are no good for precision work if it involves a lot of round or circular features since they are faceted and it will be milled as such even with a high mesh density, whereas other filetypes or CAM software may allow proper arc interpolation so the circle is at least as good as possible?
    May 2004
    4519
    Maybe you are confusing several different terms: Accuracy, precision, detail, and complexity.
    STL is not the best file format for true arcs as you indicate. Some CAM software will approximate arcs for the best fit.
    What are you actually trying to accomplish?
  1. Importance of squaring workpiece and/or vice
    By outsider787 in forum Benchtop Machines
    Last Post: 07-29-2012, 04:52 AM
  2. Importance of over-voltage?
    By crochambeau in forum Stepper Motors / Drives
    Last Post: 04-06-2010, 01:38 PM
  3. PRECISION WELDER LOOKING FOR WORK
    By microfusion in forum News Announcements
    Last Post: 07-04-2009, 09:51 PM
  4. First attempt at precision work : success, but...
    By Cowbell in forum MetalWork Discussion
    Last Post: 02-09-2006, 10:02 PM
