586,516 active members*
3,632 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Stepper Motor Starts and Stop
    Dec 2011
    Hey everyone, I need help on my stepper driver and breakout board the problem is that when I try to calibrate my cnc router the machine moves but then then I set the mm it moved and It says machine has been calibrated. And when I try to Jog the motor moves a little distance and then it stops but keep on making a noise like if is moving and in the computer it says is moving but the motor stays still. Any help will be appreciated thanks Here are the Driver board and breakout board spec sheets. Also the driver board is set to 1/4" step and 3A. Thanks again
    Attached Files Attached Files
    Dec 2011
    Any help will be appreciated I really need it
    Aug 2006
    2758
    Hello;
    If the motor rotates at the beginning at least a complete turn it isn't (probably) motor wiring problems. Check your connections. If you show a video with sound we could probably be more helpful. Guided by your description it seems like motor stalling. Decrease acceleration and motor speed on the "motor tuning" settings and try again. Please, modify only one thing at the time.
    Does it do it on all the axes? Tell us also about your power supply voltage and rated current.
    Best regards,
    kreutz
  1. Help! Mach 3 Won't Move my Stepper Motor - Emergency Stop Mode
    By AntonCNC in forum Machines running Mach Software
    Last Post: 03-08-2017, 02:38 AM
  2. G540 / Smooth Stepper and an E Stop
    By fragger6662000 in forum Benchtop Machines
    Last Post: 01-24-2011, 10:46 AM
  3. Quickest way to stop a stepper
    By stirling in forum Stepper Motors / Drives
    Last Post: 09-20-2010, 03:30 PM
  4. Integrated stepper motor? with built-in stepper motor driver
    By uirobot in forum News Announcements
    Last Post: 06-07-2010, 09:59 AM
  5. Beltdrive-stepper motor-stepper motor driver
    By Georg in forum Stepper Motors / Drives
    Last Post: 10-16-2007, 10:56 PM
