586,659 active members*
3,696 visitors online*
IndustryArena Forum > MetalWorking Machines > HURCO > Small shop looking at a VM-1 or VM-10
    Jan 2008
    282
    Hello all,
    I have a very small shop that is overflowing with tools. I need another vertical spindle and the VM-10 looks like it would just fit if I move out my Bliss punch Press. We are running a Haas VF-0 and a Takisawa EX-108 lathe.
    I would like to hear from those of you who are running VM-10s. What do you cut, how are they for maintenence?
    I use SurfCam Velocity 5.1 for software
    Thank you in advance.
    Lowell
    Feb 2009
    6028
    At first you'll like it. Then it all goes down hill fast. Stick with haas IMO.
    Jul 2007
    378
    Go to Hurco's web site and download the Winmax8 trail. If you like the sotfware, there is a good chance you will love there machines. Quick and easy to set up. Although if your planning to run a lot of cam stuff on it, the Haas may be a better choice.
    Which machine can you get more options with (chipconver, probes, softwear upgreades,ect)? You might want to go with that one instead.
    I do like running the VF-3, but I cus that thing every time I have to top off the swing arm tool changer oil and other general mantince duties. Pull off the TC pannel, pull off the TC gear drive pannel, add the oil. Put the pannels back on. 90+ mins later, I'm done. Hurco's are not flawless eaither, so I guess you have to pick your posion.
  1. Small shop
    By denmars in forum Fadal
    Last Post: 07-11-2008, 03:12 PM
  2. 4X4 Small Shop log
    By Trail Logic in forum Torchmate
    Last Post: 03-24-2008, 03:35 PM
  3. Small shop 3 machines
    By TT350 in forum Tormach Personal CNC Mill
    Last Post: 02-15-2008, 12:20 AM
  4. Would like to open small shop.
    By speed33317 in forum Haas Mills
    Last Post: 06-30-2005, 03:05 PM
