Hello
my problem is this ... doing Stamp basis .. but not equal to equal, even at times reached the level of letters and printed accordingly.
Please someone advise me what the problem is!
Thanks in advance!
Hello
Thanks in advance!
Are the deeper cut sections nearer the end of the laser where the beam exits?
If so I would suggest mirror alignment......the beam is weaker the further it is from the laser tube.
John
Hello
nothing changes. We changed blocks for high voltage interfaces changed the board changed the wheels for movement along the axis "Y". The result is the same. Tomorrow I will change and the lamp. If anyone has other ideas and please help.
thank you
I changed the laser tube and all is well.
Please pay attention to the laser power supply. I have noticed problems like this when there was a power supply with low voltage output, running hot, .. just not a match to the laser tube.
You should also look at these suggestions:
*Use a power line conditioner .. Similar to TrippLite model LC1200
*Ensure a proper ground from the laser machine frame to a "real" building frame
*Do not run any "odd" equipment with motors while operating the laser (blender, saw, router)
Ray Scott
Owner / Engineer
Rabbit Laser USA
513-217-5707
I changed the laser tube and everything is fine.
hi ,can you gelp me? I am lookig forward to make a stamp in this machine. I have o idea how to make it. Please let me know. I already alligned the mirrors but I havet got the nice stamp.
Joathan Rivera
