Originally Posted by
verohandymike
I like this idea, and your application for a patent is valid. Never mind what appears to be negative comments, they are actually bits of good advice. No matter what you invent I bet I can point out a bunch of reasons why you will be in for a fight. And the overseas thing is a challenge we all have to face.
I say go for it.
BTW. When I saw your device I was hoping it was designed to fit various sized tubes. So I will give you this for free... The main back plate is OK; but change the design so that it can be supplied with front plates of different sizes, and different hole patterns (even different hole patterns on the back plate) so that the clamp will fit tubes of a range of sizes. Make sense?
