586,060 active members*
4,243 visitors online*
Results 1 to 5 of 5
    Jan 2014
    18
    Daves buget 8x4 cnc router
    Well Ill start by saying im not spending thousands of ££££ on this build but I dont expect to build it for £200 I have no drawings made up yet and I plan to buy parts as and when I can afford to. So my plan so far is to buy this tb6600 controller, driver, display, enclosure, handle package in one
    High Integrate Professional 4Axis CNC TB6600HG Stepping Driver Gcode Record &Box | eBay
    Along with at first 3 nema 23 4nm 4amp 566oz stepper motors running rack and pinion drives im planning on using a steel table with adjustable hight bed im unsure of a good linear system for this size machine so am thinking of bolting on aluminum 80/20 vslot extrusion and making vslot bearings to run the x and y and linear rails on z
    I would like to hear input from others who have built large budget machines and even see some of your designs too
    cheers dave
    Don't just Buy parts, buy raw materials and make parts
    Widgit
    www.widgitmaster.com
    It's not what you take away, it's what you are left with that counts!
    Jan 2014
    18
    Thats the idea but gotta factor in price so that controller won the rest im making I wont buy the bed in kit form ill buy parts. Design and build
    35538
    Don't be too surprised when you replace that controller box with something better. There's a reason why it only costs 20% of what a high quality setup costs.
    There are countless threads here where people found out that there attempts at saving money ended up being more expensive.
    Jan 2014
    18
    Thanks for the heads up. Have you got any links to failed units? Or ones that dont perform well? Im not after speed. Would a breakoutboard and drivers work better? Can you get breakout boards that except readouts and handwheel control? What would you sugest to control the nema 23 motors I was planning on using?
    Still a newbe with electronics so any input is gratefully received
    cherrs.dave
  1. Newest CNC router machine from SINICNC-SIN-C3636 Mini cnc router
    By RoseChina in forum News Announcements
    Last Post: 09-16-2013, 07:29 AM
  2. with a Precix Table Router with Perske router
    By SignShop Grunt in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 09-08-2010, 10:08 PM
  3. Using a router for the 1st time. Need advice of cut speeds, router bits etc.
    By Apples in forum DIY CNC Router Table Machines
    Last Post: 09-23-2006, 09:33 PM
