586,111 active members*
3,724 visitors online*
    Dec 2008
    19
    Need help Setting up THC process
    OK, when I get the file I want to cut loaded into Mach3, I can cut metal that doesn't warp by leaving the THC off.
    Question: What are the steps in Mach3 to perform to properly use the THC on thinner metal that tends to move up and down while cutting.
    Let's say 12Ga w/60amp tip and .19 standoff, 280 IPM as recommended by Thermal Dynamics Cutmaster 52 manual. 110 arc volts recommended.
    I don't understand the instruction manual steps.
    I must be missing something because when I turn on THC and start the G-code file the torch goes to one spot ignites and just sits there.
    Jun 2008
    562
    Quote Originally Posted by Orangejbird View Post
    It sounds like your "ok to move" from torch or "Arc ok" in Mach is not not getting through. Does your Arc OK button light up when the torch fires? I've attached a Plasma xml for Mach that works with my DynaCNC 6000 and a Cutmaster 52. You will have to set up the ports and maybe some pins for direction but it works for me. (Use at own risk). In other words stand by the reset button. Let me know if it works
    Good Luck
    Mike
    Attached Files Attached Files
  1. How setting tools and setting offset
    By John246 in forum Sharp CNC
    Last Post: 04-09-2016, 08:31 PM
  2. Help with process
    By aadamson in forum SprutCAM
    Last Post: 03-07-2012, 07:29 AM
  3. Help setting up post process from TCC to Mach3
    By 56speedster in forum Uncategorised CAM Discussion
    Last Post: 03-29-2008, 04:14 AM
  4. In the process
    By Smitty911 in forum Dolphin CAD/CAM
    Last Post: 05-10-2007, 06:34 AM
  5. Tig Process ??
    By millman52 in forum Welding Brazing Soldering Sealing
    Last Post: 04-30-2007, 07:41 PM
