586,655 active members*
3,562 visitors online*
Results 1 to 7 of 7
    Nov 2005
    938
    a3977sed chips
    Well, my free samples came in. Those damn things are small.
    Any suggestions on how to handle the soldering of them other than (1) carefully, (2) steady hands and (3) Large magniufying glass?
    Their going into the s3977 of Phils (actually it's oes modification with the 12V regulator.
    Steven
    Jun 2003
    3312
    Flux, a holding device, fine tipped soldering iron no more than 25W. One of the challenges with a homemade pcb is the lack of solder mask. You can help by getting a pen that does solder mask repair. And practice before you put the actual chip on.
    http://pminmo.com/forsale/1X72805.pdf read page two in red and look at the picture of the holddown.
    Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
    Vist my websites - http://pminmo.com & http://millpcbs.com
    Nov 2005
    938
    I was thinking of using a on top of board (as opposed to through the board) socket. I've identified a couple at digikey for about 75 cents each
    Apr 2003
    32
    2 wrongs don't make a right
    But 2 Wrights makes a Airplane
    Kevin Matney
    www.Matneymodels.com
    734 - 848 - 8195
    "IN GOD WE 'TRUST "
    Jun 2003
    3312
    A3977SED and A3977KED are the same part, just the lead free version. Digikey has both:
    Digi-Key - 620-1146-1-ND (Manufacturer - A3977SEDTR-T)
    Digi-Key - 620-1144-1-ND (Manufacturer - A3977KEDTR-T)
    Mar 2013
    Hi everyone I'm not very well versed in any of this, however I'm trying to build or have a stepper motor and controller built. I found a controller on ebay that I think will work for my application. It has 4 Modes
    1) Jogging forward/back 2)Momentary on off 3)speed up/down 4)Set points A-B
    My question is would it be possible to wipe out mode 2 and 3 and replace them with mode 4 then just have 3 different sets of set points?
    Mar 2013
