586,121 active members*
3,262 visitors online*
    Apr 2007
    151
    Eratic Machine2
    Have tried posting on mach support but its not listing? My SyilX3 is cutting elipses instead of circles, I am using a file that has worked before and double checked in the simulator, so I assume the problem lies with the machine.
    I have attached the file and the xml ( had to rename it xls as site won't exept xml)
    Can anyone help?
    Mike
    Attached Files Attached Files
    Apr 2007
    151
    Problem solved, loose motor to ball screw coupling all is now well
    Mike
  1. Eratic Machine
    By mikemill in forum Syil Products
    Last Post: 04-26-2012, 09:45 AM
  2. eratic recko 320 servo drives
    By Capteod in forum Mach Software (ArtSoft software)
    Last Post: 09-10-2008, 04:32 AM
