586,121 active members*
3,758 visitors online*
Results 1 to 7 of 7
    Mar 2011
    4 axis foam cutter
    Hi all,
    In March last year I started to build Linistepper for my machine. At that time I started a thread here: http://www.cnczone.com/forums/open_s...tepper_v2.html
    The whole project was paused til last month but now it is almost finished.
    For testing and learning I choose letter cutting. For drowing I use AutoCad, for generating G-code I use DeskCnc and for cutting I use Mach 3.
    I was cutting some letter with success, but I have problem with islands.
    My problem and question is:
    Can someone explane how to create islands like on letter "O,P,B" etc.. with AutoCad or DeskCnc ?
    Here is some pics, on this pics machine was not at real position, this was for testing purpose:
    Mar 2011
    Ok, I found the way to make islands, but now I have other problem..
    Today I was trying to configure my machine with Mach3 and have one big problem.
    When I move motors with hotkeys, they move fast enough but when I load G-code machine move too slow!
    I make drownings in autocad then convert to gcode with deskcnc and cut with mach3.
    This is my motor configuration: motors are 7.5° so i guess that is 48 steps per revolution. My drivers are configurated to run under half step mode so in mach3 under motor tuning i put 192 steps per, because my machine move 1mm per one motor revolution! When i change velocity in mach3 only diference i notice is the speed when i move machine with hotkeys but when i run gcode speed are the same-too slow.. I do change native units to mm in mach3 and deskcnc.
    Cen someone tell me how to incrase movement speed ? When I change feedrate in gcode only thing that change is movement speed till the wire come to the part that need to be cut, and than again too slow !
    Please someone, I'm stuck, I try to google for some tutorial but found nothing to be useful.
    Thanks in advance!
    Apr 2005
    438
    Been a long time I have used my router but I believe while you have Mach3 running hit the P"TAB" key it will be in a window and you can change the speed settings.
    Mar 2011
    Thank you lovebugjunkie for reply !
    I fix my problem, I set steps per mm to 368, velocity to 600 and acceleration to 200 and now everithing is ok, I can change speed by changing the feedrate in gcode and accuraci with drowning is almost perfect, at 15 inch part I have 0,5 inch dismatch, so a little bit tuning and calibration will be done.
    Apr 2005
    438
    Sorry I was pointing you in the wrong direction. I have though about building a cnc foam cutter many times but have never came up with a way to mount and move the towers that did not require a pay check . Like the way you used the slides and U channel.
    Mar 2011
    Don't be sorry, I don't know much about all this, and I appreciate a lot your reply!
    Any advice and comment means a lot to me!
    Now I need to pratice making drownings and g codes, Some drownings are cutted perfect and some drownings are cutted with fault. I guess that I make some fault in deskcnc, so practice will be the main job of me and my machine in next unknown time period .
    May 2012
    Need help!
    I am a newby trying to figure out what I am doing and how to do it
    I need educated in stepper motors
    can anyone help me out as to what and how to function here?
  1. Yamaha XY 2-axis conversion to CNC foam cutter
    By jlaiii in forum CNC Machine Related Electronics
    Last Post: 11-29-2009, 03:45 PM
  2. MACH 3 & 4 axis foam cutter
    By richbads in forum Machines running Mach Software
    Last Post: 11-06-2009, 08:30 AM
  3. Using Mach3 with a 4 axis foam cutter
    By richbads in forum CNC Wire Foam Cutter Machines
    Last Post: 10-29-2009, 12:27 AM
  4. New Design - Hybrid 3-Axis Router/4-axis Foam Hot Wire Cutter
    By the__extreme in forum CNC Wood Router Project Log
    Last Post: 02-26-2007, 09:58 PM
  5. MS Excel 4 Axis CNC Foam Cutter Experiment
    By arman in forum CNC Wire Foam Cutter Machines
    Last Post: 10-25-2006, 09:04 AM
