586,655 active members*
3,708 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > V24 Tool Libraries not loading
    Jan 2011
    380
    Question V24 Tool Libraries not loading
    Hello all,
    Searched forum but didn't find answer on this. We bought another seat license for Bobcad V24. Has been setup on a system identical to the first seat in all aspects. Spent many many hours creating tool library on first system. I copied the tool file for mill and lathe and put them on new system. They are not loading in program. When I go to choose tool for either lathe or mill, I get the default tools. I searched drive and only found the tool files in the Bobcad-cam data folder under milling and lathe technology. I have even tried removing ALL files in both tool folders. Restarted bobcad, and it still brings up the default tools in the dialog boxes, etc. My question is, where is it seeing these default tools if the file is not even there? I am stumped as to how to bring in the tool library. I REALLY don't want to have to create all tools again on new system. In AutoCAD and Inventor, etc, you can use same tool libraries. I would think you could here too. Any ideas on how? Or am I doing something wrong? Thanks for your input on this.
    Tony
    Mar 2012
    1570
    Moving Tool Files
    BobCAD CAM V24:
    C:\BobCAD-CAM Data\BobCAD-CAM V24\MillingTechnology\Tools\Mill
    This is where BobCAD saves your tool files.
    In this folder there are 5 mtools files
    defaultTools.defmtools
    LaserToolFile.mtools
    PlasmaToolFile.mtools
    ToolFile.mtools
    WaterjetToolFile.mtools
    You would want to copy the ToolFile.mtools from one computer to the other.
    Al DePoalo
    Partner Product Manager BobCAD CAM, Inc. 866-408-3226 X147
    Jan 2011
    380
    Yes, as I said in my post I tried to move the files already that you stated. Did not work. But in any case, I resolved it myself. Uninstalled BobCAD and then reinstalled. Works fine now, have no idea why it didn't use the files on the first install.
    Thanks anyway
  1. Loading Tool Magazine
    By rmetzger2 in forum Bridgeport / Hardinge Mills
    Last Post: 04-24-2012, 11:47 PM
  2. need help loading tool
    By pro_cutting in forum Cincinnati CNC
    Last Post: 10-30-2011, 02:09 PM
  3. Loading tool geometries
    By tamedia1 in forum BobCad-Cam
    Last Post: 11-17-2009, 11:42 PM
  4. Loading tool geometry with G10 ???
    By theemudracer in forum Fanuc
    Last Post: 12-11-2007, 02:06 AM
  5. Confused by tool libraries
    By MichaelHenry in forum SprutCAM
    Last Post: 12-31-2006, 06:05 PM
