Originally Posted by
PortlandGTS
Not really. But I've realized there's easily 1/16" of flex in the tongue. I'm going to start over with all the measurements soon using the 1' marker as the starting point rather than the tongue. (I've been tied up in other things since my initial post, and may not be able to do anything more for another week.)
Tom
Instead of measuring the machine travel with gauges and tape measures, I recommend cutting something to a length like 12", 36", 48" and then measuring the results. That's the end goal anyway, and it's easier to measure edge to edge of the cut material. As long as you don't have backlash, there may be mechanical tolerance buildup causing the 1/16" offset.
That's a lot of error for the distance you are measuring though. If there is no cure other than replacing mechanical parts at more expense and effort than you are willing to accept, then adjust the steps per inch value until you dial out the error - and get on with making interesting stuff to show us.
CarveOne
http://www.carveonecncwoodcraft.com
