Hi Guys,
I have built a 2 axis foam cutting machine that utilizes an abrasive wire to cut through foam, rockwool and other insulation materials.
I have used Mach3, and the machine has operated well for a couple of months. However, the y axis is mounted on a moving x - axis gantry, and although I have added large counter weights, to balance out the heavy y axis, I had problems with the motors not being able to cope with the load.
I have added a 19:1 reduction gearbox to the y axis, and this works very well, the motor now is able to cope with the load.
I am however loosing some accuracy with this, it seems like we are loosing about 5mm over a 1500mm travel on the y axis.
I have tried to add some backlash adjustment in, with not too much luck.
Has anybody had any issues with Mach 3 and gearboxes before ?
Any suggestions ?
