586,100 active members*
2,737 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > 3 AXIS cnc router electronics
    Apr 2012
    Hi there.
    i've recently started building my own cnc router . I bought 3 nema23 steppers kit this is what i got:
    •1 x New 3 Axis TB6560 Driver Controller Board 1/16Microstep, 12-36V, 1.5A-3A
    •3 x New 57BYGH56-401A Single-Shaft Stepper Motors 1.26Nm/175oz-in 2.8A
    •1 x New 24V 10A power supply
    Do i need drivers still for each motor all will this run sraight off on emc2. And if not what all do i need to get to get it all running
    thanks Denrow
    Jan 2010
    2141
    Theoretically you have what you need (that is, if you also have a straight-through 25-conductor cable) to get going (not counting mechanical parts such as motor shaft couplings, enclosure for the driver board, cables to the motors).
    Some people have had success with TB6560 boards, while others have encountered problems of one sort or another. You may be interested in reading through the following thread for more information:
    http://www.cnczone.com/forums/genera...y_chinese.html
    Apr 2012
    The cable i dont have is that just a parallel port cable?
    i take a look at the thread
    thanks for the help
    Jan 2010
    2141
    Quote Originally Posted by Denrow View Post
    thanks for the help
    That is a parallel port cable, but it is best if you double-check to make sure that it passes all 25 pins straight through (some 25-pin cables do not have wires for all of the pins, or the wires may connect to different pins on either end).
  1. 3-axis Machine - Electronics Diagram
    By Manuks in forum Stepper Motors / Drives
    Last Post: 10-09-2012, 08:52 AM
  2. 4x8 new router build Electronics
    By hacker7 in forum Open Source CNC Machine Designs
    Last Post: 03-30-2012, 01:59 AM
  3. Replies: 4
    Last Post: 08-28-2010, 02:39 AM
  4. New Design - Hybrid 3-Axis Router/4-axis Foam Hot Wire Cutter
    By the__extreme in forum CNC Wood Router Project Log
    Last Post: 02-26-2007, 09:58 PM
  5. COMPLETE 3 axis electronics package (plug-n-cut, Ready to go)
    By ballendo in forum News Announcements
    Last Post: 05-30-2006, 10:50 PM
