586,082 active members*
3,837 visitors online*
    Apr 2011
    132
    machining plastic
    Hello,
    I need to make a grove with a endmill Ball on a piece of plastic but I only have a 4 flute can I use that on plastic or I need a 2 flute?
    tx
    May 2004
    4519
    4 flute will work fine. Will have to run a slower feed to allow for chip evacuation balanced with correct RPM.
    Mar 2011
    215
    I'm a noob myself but from what I've read you want to use a 1 or 2 flute bit if at all possible. The more flute the more melt you will get. Use air or soapy water helps (but not alot in my experiance...) But as it is now all I've been able to use is a 3 flute vbit on acrylic. I've tried extruded and cast. Both seem to act very much the same although cast is supposed to cut easier. I've just received my 2 flute vbit today so I will be trying that as soon as my new order of acrylic shows up. Hopefully it will go much smoother.
    Mar 2006
    489
    He didn't say what type of plastic.
    There's a huge difference between cast and extruded acrylic. I can cut extruded acrylic and 150ipm, .06DOC, 24krpm, 1/16" 2FL end mill all day with no melting. Extruded melts the second you plunge into it and you hear that $6 'SNAP'.
    You can use any flute count you have, but generally for plastics, use less flutes for the best performance. Uncoated mills (like the ones for aluminum) are also better for plastics, as they are sharper than coated ones.
    Paul
  1. Machining plastic
    By WATERJET71 in forum MetalWork Discussion
    Last Post: 04-03-2012, 10:16 PM
  2. machining UHMW OE plastic
    By Am5687 in forum Glass, Plastic and Stone
    Last Post: 12-18-2011, 04:42 PM
  3. machining plastic
    By mmiranda in forum MetalWork Discussion
    Last Post: 07-04-2009, 04:42 PM
  4. Machining Plastic (Centriboard) what bit to use?
    By abelloise in forum Glass, Plastic and Stone
    Last Post: 07-09-2007, 05:01 AM
