586,100 active members*
2,749 visitors online*
    Sep 2008
    37
    Z AXIS raising up
    we use our CNC to cut foam inserts. we have a 10x4ft board that we arrange multiple inserts. the problem we seem to be having is that the the first insert cut perfectly, however the further away from the origin the higher up the the z axis doesn't not return to the correct depth, win CNC tells us that the z is at the correct height, when its higher than it should be. The Very confusing point about this problem is that its not a consistent fault. some jobs will cut at the correct depth throughout the sheet, and the next job will have the fault,
    Im at a complete loss to why this is happening any help would be greatly appreciated.
    There is always another option.
    If it's a stepper powered Z axis, it's probably losing steps. Try decreasing your acceleration by 25%.
    Sep 2008
    37
    Thakyou for your swift reply, the motor is a servo motor, any suggestions?
    Noise on the encoder line?
  1. Raising up a vise
    By webgeek in forum MetalWork Discussion
    Last Post: 11-08-2010, 03:49 AM
  2. Raising Taig headstock
    By MechanoMan in forum Taig Mills / Lathes
    Last Post: 04-14-2009, 10:29 PM
  3. Raising Voltage from 12 to 24v
    By Marcvw79 in forum Hobbycnc (Products)
    Last Post: 03-11-2008, 11:29 PM
  4. Techno-isel Z axis keeps raising at end of program
    By irishii75 in forum Techno CNC
    Last Post: 08-25-2007, 02:51 AM
  5. Keeping your zero when raising the head
    By wcarrothers1 in forum Benchtop Machines
    Last Post: 02-10-2007, 07:37 AM
