586,075 active members*
3,871 visitors online*
    Apr 2012
    Mach3 output signal
    I am trying to drive one stepper and I connected the circuit and tested it using the Breakout board software, the motor spins perfectly but with Mach3 the axis pul LED in the BB just have a dim light and the motor don't spin >>>>I think it is the output signal from mach so How can I change it?
    Help PLEASE
    Apr 2012
    This fourms help me alooooooooooooot
    Jan 2010
    12
    mach 3 output signal
    what stepper driver are you using?
  1. How to send the same output signal for two axis
    By panto in forum Mach Software (ArtSoft software)
    Last Post: 04-29-2011, 10:47 AM
  2. 1.6V-3.0V random signal voltage parallel signal from output – Any advice?
    By cjchands in forum Mach Software (ArtSoft software)
    Last Post: 11-12-2009, 11:36 AM
  3. Input/output signal on 0M-C
    By padobranac in forum Fanuc
    Last Post: 10-28-2008, 03:49 PM
  4. No Output Signal
    By tz1238 in forum Machines running Mach Software
    Last Post: 01-27-2008, 09:57 PM
  5. Diag: Output Signal: Enable 1 help...
    By Flatline's Up! in forum Syil Products
    Last Post: 04-06-2007, 08:11 AM
