586,106 active members*
3,134 visitors online*
IndustryArena Forum > Mechanical Engineering > Linear and Rotary Motion > Making a safety enclosure - ideas for door mechanism?
    Jan 2012
    I have to make a safety enclosure for operating a laser. The door itself is going to be hand-operated and needs to slide up. See this example:
    http://i.imgur.com/v8VMy.jpg
    I'm going to be making the enclosure from t-slot extruded aluminum as it should allow me to build fairly quickly without forming sheet metal. Any ideas on how i can make this door assembly slide up and then stay up until it's pulled down? Sounds trivial I just don't know where to start
    24221
    If it is purely manual operation for up and down, then depending on the weight, you may need a simple counter balance, and to retain it in the up position, could be a simple permanent magnet arrangement or small electromagnet if necessary?
    If this a safety door, then you most likely require interlock/confirmation switches on closed or detection on both open and closed position.
    There are special safety switches that defeat overiding.
    Al.
    Albert E.
    May 2004
    4519
    Consider spring loading so that it opens itself when unlatched. Can also include an interlock in the latch. Operator is forced to close the door before cycle start is allowed.
    24221
    If this has to conform to OSHA for safety.
    see ebay 300701155058
    Al.
    Albert E.
    Apr 2007
    1955
    The laser enclosures I saw europe had double walls, with sensors in between the walls. If the laser beam was detected in between the walls, then it shut down the laser. This construction was used on every aspect of the enclosure, including floor, ceiling, and doors.
    The shutdown time was a fraction of a second (no idea exactly how fast) because the cutting speeds were amazingly fast.
  1. Machine door safety lock
    By jkowal in forum Uncategorised MetalWorking Machines
    Last Post: 05-02-2012, 03:35 PM
  2. Hurco door safety switches
    By suntec in forum HURCO
    Last Post: 02-17-2011, 07:03 PM
  3. How to turn off the open door safety switch
    By dingo0722 in forum Haas Mills
    Last Post: 01-21-2011, 12:40 AM
  4. Replies: 15
    Last Post: 08-13-2010, 01:24 PM
  5. Scratch-Resistent Material for Enclosure Door?
    By dtronvig in forum Benchtop Machines
    Last Post: 09-24-2007, 07:13 PM
