I haven't seen much feedback in other threads about this, so I'll start a new thread dedicated to it.
Other than needing to be mechanically synchronized, what complications are there with ganging multiple stepper motors together mechanically? I am contemplating using multiple motors on one axis to get more torque. I would probably use a short belt or chain to connect them. The reason for this is that several less powerful motors can be purchased for much less money than an equivalent single motor. So, if I can use two motors together on a single axis, it might be worth a try.
Assuming the driver can handle the current, could the motors be electrically connected, as well?
One side effect that might be nice is that by putting two motors in parallel, the inductive reactance is cut in half reducing it's effect on the time constant, so a lower voltage could be used to achieve the same time constant, or a shorter time constant (faster max speed) could be had with the same voltage. (at least in theory)
Comments?
Dave
