I started looking into tool change capabilities for Sherline / Taig mills and was greatly disappointed at what I found to be available and the cost of such equipment more than stunned me.
Contacting IMSsas almost gave me a heart-attack, don't get me wrong, I can understand the need for business to make a profit but charging $580.00 for one clamp and one tool holder or $420.00 for one clamp and one tool holder with a minimum quantity of 20pcs is ridiculous.
A2Z makes some nice products but the cost of their stuff makes it hard for the average home/hobby machinist to consider because the prices are so high that they often settle for less stable, less accurate but almost free solutions because there isn't really any other options.
The IMS QuickChange while a novel concept has too many issues with tool holder slippage and the ISO10 with ER11 collet based spindle suffered the same slippage at low RPM but the extremely high costs of these two options put it out of reach for most hobby machinist so I decided it was time to make something better available at a more reasonable cost and allow the user to buy only the pieces they need/want.
Slippage occurs because there is not enough seat pressure between the tool holder and spindle taper, I purchased both style of tool change spindles and started taking measurements, the QuickChange has only 40lbs (179N) and the ISO10 while a little better only had 158lbs (702N).
Further testing and calculating I found that a minimum target force of 224lbs (1000N) is required and while the ISO10 is rated for 268lbs (1200N), the available implementation is not capable of this.
I did like the ISO10 tool change spindle with internal air-cylinder because it was very compact but the internal space is what prevents the force from reaching the required strength to prevent slippage (it has to exceed the force required to overcome the seat force).
I decided that doing it internally just wasn't going to be an option unless someone figured out how to generate significantly more force in such a small space and still maintain the 7mm of gross drawbar travel without forcing me to rob a bank to buy it.
I decided that that minimum target force would be 280lbs (1250N) so I opted for the ISO15/BT15 size tool holder which is rated at a maximum of 380lbs (1700N) and if I ran it at the minimum target or just above it, slippage would not occur at the low RPM
I chose the ISO15/BT15 size tool holder with ER16 collet end for many reasons, this allows greater flexibility in tool options and by utilizing a timing belt the RPM can be increased to 5,000RPM without sacrificing performance and making the components should be simple enough for most machine shops.
If there is sufficient interest in a conversion kit I see no reason why I couldn't mass produce the parts to lower their cost.
I have a reliable source for tool holders ($59.00ea - less than PDS charges) shafts (P20 Tool Steel - HRC52) and clamps (9160 Spring Steel - hardened/tempered) would run around $250.00, a suitable air-cylinder with a 5port 2way 24VDC pneumatic valve would be around $75.00 and belleville disc springs are cheap so it doesn't have to be expensive.
You might think these prices are high but lets examine it closely, buying these parts gives you a tool change capable spindle for less than $500.00, at least 1/3rd the cost of the QuickChange and 10 times better.
If you made your own shaft and clamp then sent them out for processing, hardening cost $180.00 per lot and tempering costs $160.00 per lot and after you get them back you have to send them out for grinding so your minimum cost is now $340.00, grinding isn't cheap either and if the grinder isn't experienced with shaft grinding where TIR is critical, your shaft might have a TIR of 0.010 which is completely unacceptable for a product with a maximum acceptable TIR of 0.00080
Taking into account that you start with a piece of 1-5/8 round stock P20 Tool Steel 8in (200mm) long (cost is $29.00) and then gets turned down to size, without the equipment to do it yourself you're paying for this service and the minimum shop labor would be $80.00 plus whatever setup fees they charge and finding 9160 Spring Steel isn't as easy to find as other materials.
I'm not stopping anyone from making their own, only offering what I believe to be an affordable option to a better solution by sharing the cost of producing 25pcs.
I've attached pictures of where I am at with my prototype and I should be done within the next two weeks and will be ready to (mass) produce the final product for use so if anyone wants one they need to send me a direct e-mail and climb aboard.
