Originally Posted by
WSS
You will probably need a steel gantry for anything over 30mm. The heat from cuts like this is fairly high, more than enough to wrinkle an aluminum extrusion gantry. The cut speeds on 30mm (using a hi speed tip) is probably in the 10-15ipm range. Preheat (w/o a hi/lo system) on 30mm (using lpg) will be 1-2min. Just the preheat time, being stationary in one spot is going to be a problem. Even if the gantry is a floor rail, independent of the table, you will see flex that can't be compensated for due to the heat being in different spots every pierce. Steel will probably end up being cheaper too.
A servo system is also going to work better for the extreme cutting speed ranges you need. Servos have a wider torque curve than steppers for jobs like this, meaning you can have better quality on thinner and thicker plate.
WSS
