Originally Posted by
twocik
The TTS Fly cutter tool sounds promising for a low HP machine and can tell you I'm seeing the same results as Scott with the FM45. My GMT will almost stall my machine at full woc, .03 - .05" doc, 2500 at 60ipm. I normally run my cutter at less woc when possible, .025 - .035" doc, 55ipm at 2500 rpms. Without lube it will get very close to the red, however with a little coolant it will push right through at full woc. I've face over 300 1"x4"x7" 6061 blocks with a .129" carrier with no issues but .05" or more doc would be nice at 70 - 90 IPM. I always thought it could be due to the weight of tool too.
Any HD pics of the Tormach fly cutters finish on your parts ?
