586,655 active members*
2,356 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > Change - from linear path control to CNC path control
    Aug 2005
    26
    Lightbulb Change - from linear path control to CNC path control
    I have bought a Maho MH 400P - see following
    I would like to have changes - from linear path control to CNC path control
    1) Which electronics (Gecko, Rutex, ???) should I use?
    2) Which Servo Motor (in each case for the axle X & Y & Z) should I use?
    - the Servo Motors are missing
    Thank you in advance - Sorry, I am an electronics beginner :banana:
    Fidibus
    PS: The software Mach3 is set
    24223
    Do you have three motorized (servo) axis right now? If so you have the motors and amps.
    You would need to know however what type of control the amps have analogue/step&dir?
    Is there steppers or servo motors.
    I assume it is just point to point positioning at present and you want to do interpolated motion?
    Depending on the above, You may just need the software.
    Al.
    Albert E.
