586,069 active members*
3,685 visitors online*
    Oct 2009
    28
    Block Syntax Error II
    Hi there,
    I have a Cincinnati arrow 1000 with the acromatic 2100. Ive been having this problem for a while now. After the machine has been on for a couple hours if I put code into the MDI it tells me that I have a syntax error. Even though I've been using the exact same code in the past. It doesnt matter what is entered. It comes up with te same error. The same code will work fine on the program side. It used to be that if I shut the machine down overnight it would go away. Now it doesn't matter. Any input is greatly appreciated.
    Thank you
    SC
    Mar 2011
    463
    Sounds very similar to a post about a month ago (Alarm 48-72 : Block Syntax Error).
    Based on the descriptions I can't say yours is the same problem, but it is similar enough to try the fix I gave him. Delete everything in your MDI screen and retype the code.
    Oct 2009
    28
    Thanks for your help. I found the previous post. I'll give it a try.
  1. Alarm 48-72 : Block Syntax Error
    By t_hum in forum Cincinnati CNC
    Last Post: 05-08-2012, 03:37 PM
  2. Replies: 15
    Last Post: 09-27-2009, 07:15 PM
  3. Auto Tool Zero VBA Code gives Syntax Error
    By kiltjim in forum Mach Wizards, Macros, & Addons
    Last Post: 02-03-2009, 12:32 AM
  4. syntax error
    By pyroracing85 in forum G-Code Programing
    Last Post: 01-28-2005, 02:09 AM
  5. Syntax question
    By doug6949 in forum Mastercam
    Last Post: 12-13-2004, 08:14 PM
