I am working on a new product and so time will tell how much the quantity will go up over time. To start with I am going to need 25-100 at a time. I have drawings for each part I can email you if you want. I am posting some pictures of the parts below for now. One part is a 10 inch long solid aluminum rod tapped on each end with 6x32 thread mill stock finish. Second part is a small domed cap with a 1/16 hole drilled through the top side to side.Third is a 17x13 frame about an 1inch wide cut out of 1/8 thick aluminum. I will do my best to give you prompt responses and any additional info that will make pricing this easier. Thanks for your time and help. [email protected]
